Cluster removal tool needed
Old Feb 1, 2013 | 02:12 PM
Chiwang11's Avatar
2000 mercedes e320
Need one cluster removal tool , don't need a pair. Will pay.
Old Feb 2, 2013 | 01:48 PM
Chiwang11's Avatar
2000 mercedes e320
Cluster pull tool
I did make one with wire but still cannot pull it out . It did start to move out a little bit.
Old Feb 2, 2013 | 04:55 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
The reason they are sold in pairs is that you need to pull a little on one side and then a little on the other to 'wiggle' it out. Pulling on only one side just causes it to jam. FYI - they're pretty cheap.
Another alternative is to remove the panel under the steering wheel column. You can then push on back which sometimes helps.
