reverse light and dash light problem
Old Feb 3, 2013 | 08:00 AM
sandstar's Avatar
320 cdi w210
Unhappy reverse light and dash light problem
hi guys, i have a w210 e320 cdi .
it has a problem with the reverse lights not coming on when you put it in reverse gear and also there are a couple of lights out on the dash and the central column.
when i took to garage they advised that it was a fuse box in the drivers side foot well. since went to parts department and they say the only fuse box is on the light switch (ma210 545 05 04) control module. can anyone help to show as can't find and would appreciate and photos showing how to remove and fit if this is problem .
many thanks in advance
Old Feb 4, 2013 | 02:05 PM
sandstar's Avatar
320 cdi w210
do you have pictures , i do have bulb warning on dash, garage said that selecter was ok and that it was faulty fuse box under driver side , i am guessing its the one on the left hand of the dash cluster. can you show how to access?
