My Xenon headlight problem. Please help.
Old Feb 7, 2013 | 08:51 AM
magicman320's Avatar
00 E320 Wagon 4matic
First off 100.00 bucks at Autozone is too much for a damn bulb.
Anyway when i went to remove the old bulb , This is what i saw....EWWWWW.
Any suggestions?
Old Feb 7, 2013 | 09:28 AM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
For my OEM hid setup, I changed the D2r bulbs to 8k (more blueish color). Look on ebay, they sell D2R bulbs in a wide array of kelvin colors. OEM is 4500k. Those bulbs can be had, plug and play, look just like OEM for like $20. Make sure you specify its just the D2R bulb and not a full HID kit.
Old Feb 7, 2013 | 11:19 AM
desired_speeds's Avatar
2007 SL55 AMG
Did you clip the connector in correctly? Those are Philips bulbs and not some eBay ones and commonly fry something.
Old Feb 7, 2013 | 12:11 PM
Not sure what your asking but if you look closely at the picture the bulb has a crack in the outer brown bar. Would that have caused the frying?
Does this mean that i need to replace the ballast?
or can i clean the connector socket and just put in the new bulb?
Old Feb 7, 2013 | 02:20 PM
2007 SL55 AMG
The crack in the brown bar wouldn't cause this. It may be that the red connector wasnt clipped onto the bulb correctly. I would carefully clean the contact on the red connector with some sandpaper and put it back in with a new bulb.
Old Feb 7, 2013 | 06:12 PM
illest's Avatar
w210 AMG or S213
clean the connector and swap the bulb from the other side to be sure its ok.
