Rust color spray
Old Feb 15, 2013 | 06:39 PM
Brau0318's Avatar
Mars Red 2005 C230k, 2001 E320 4matic
Rust color spray
I've found something odd. I dont know much about what the cause could be so I'm just going to post pictures. Hopefully someone can atleast get me started in the right direction. It appears to be spraying outward and upward by looking around on from the spray on the hood in the first picture.
Attached Thumbnails Rust color spray-optimized-20130215_165913.jpg   Rust color spray-optimized-20130215_165923.jpg   Rust color spray-optimized-20130215_165928.jpg
Old Feb 15, 2013 | 06:51 PM
Fabio D's Avatar
210 55
Remove the supperior nut of the front/left shock, you would see a rubber, remove it too. and you need to do a weld repair in the rubber metal support, they cracks the factory welds, and the spray you see is water/dust/sand/rust comming in by the tire/road.
Fabio Daniel
Old Feb 15, 2013 | 07:06 PM
Brau0318's Avatar
Wow that was quick. Thanks Fabio. I just wasn't sure which words to use in a forum search.
Old Feb 15, 2013 | 07:24 PM
Fabio D's Avatar
210 55
Hahahahahaha, happen in my car too Just check and let us know for general info hope it helps, and let me know if you need some other info about friend
Fabio Daniel
