Return diesel line from injector leaking.
Is the air bubbles normal and what specification of pipe should I be after to replace the leaky bit?
I see the metal lines that run from the pump; the leaky line is indeed one of the non metal ones. Theres a braided hose going from each injector then a plastic hose going from the injector closest to the front of the engine back to the fuel filter. It's this last plastic one that's leaking. Return line I guess. I'm thinking maybe its a botch job given all the others are braided much higher quality material.
I'll post a picture tonight and then hopefully I can get an idea to what replacement part I should get.
