98 E320 Alarm System
Old Mar 10, 2013 | 11:57 AM
mpm414's Avatar
E320
I have a 98 E320 with 145K miles on it. Every once and a while, I have issues with the power locks and the alarm system. Is it possible to deactivate the the alarm system and still be able to use the car. I really do not care if the power locks work or not. I just want to be able to lock it and not worry about the alarm going off.Nobody pays attention to them anyways. Thanks!
Old Mar 10, 2013 | 07:35 PM
mpm414's Avatar
E320
98 E320 Alarm problem
Originally Posted by Plutoe
The alarm system is intergrated into the PSE control under the back seat!! why disconnect the unit when you can fix the issue with the locks!!
I want to be able to lock the car without engaging the alarm system. When the locks refuse to process a signal from the remote and it is necessary to open the door manually, the alarm goes off. I then have to disconnect the battery in hopes that when I reconnect it, the alarm will cease. I don't need the automatic door locks or the alarm system. All I would like to do is able to unlock my like the old days before all this technology made life (better ?). Besides I have already spent over $3K to have the problem fixed and the shop said that they cannot isolate the problem. Even at my advanced age of 59, I can still open the door without a key fob. If any of you out there have any input with the boys in Germany, maybe you can teach them about the benefits parallel circuits in their designs.
Old Mar 11, 2013 | 07:29 AM
mpm414's Avatar
E320
Alarm
The good news is that all you have to do is disconnect the connector to the PSE--all will be clear!!
Thanks for the info. Where and what is the PSE and how do you disconnect it?
