Changed my brake fluid today, so easy!
Old Aug 24, 2003 | 12:36 PM
Lightman's Avatar
1999 Mercedes E300 TurboDiesel
Cool Changed my brake fluid today, so easy!
I got a motive brake bleeder kit and changed the fluid on my E for the first time 2 nights ago. I got it at www.germanautoparts.com but I'm sure it's available elsewhere. You simply fill it with fluid, it screws on just like the cap, onto the brake fluid reservoir. You pump it up to 15psi by hand, there's a little gauge. Then you just go to each wheel, push the little bit of clear plastic tubing that came with the kit onto the bleeder valve, then loosen the valve. Fluid will drain into your container etc. I used ATE super blue. This way you can see the old tan fluid coming out and once it's fully blue you know that line is flushed. Right rear, left rear, right front, left front is the order I used. Took about 30 mins. One person required, no brake pumping, no air in the brake lines. Woohoo! $45 for the bleeder and $10 for fluid. Sure beats what the stealership charges, and then every time after that is just the cost of a new bottle of fluid! You simply switch from ate tan to blue and vice versa.
Old Aug 24, 2003 | 08:59 PM
michakaveli's Avatar
E300
Where the Cummins in your signature?
Old Aug 24, 2003 | 09:01 PM
Lightman's Avatar
