Does anyone know if 19” Brabus Monoblock V
Old Apr 18, 2013 | 03:29 PM
pauljgelinas's Avatar
2001 E320
Does anyone know if 19” Brabus Monoblock V Front 85. JX19. 35mm Rear 10JX19 25mm will fit and work well on a 2001 E320
Old Apr 18, 2013 | 05:12 PM
siopaolover's Avatar
1998 E320
the fronts will be fine. I'm not too sure about the rears though. with ET25 and a 10" wide wheel, it might not work too well
Old Apr 18, 2013 | 06:34 PM
2001 E320
Can you suggest the best sizing?
Old Apr 18, 2013 | 07:08 PM
1998 E320
for a 19x10, an ET38 would be good. I had a set of rotiform MIAs which were 19x10 ET38 in the rears and it fit really nicely on another member's E55.
Old Jun 10, 2013 | 10:48 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
You will have rubbing issues with the rear wheel set. Brabus recommended a 9.5Jx 18 with either 35 or 30ET and a 275 series tire. Stock from Brabus for the B9 model was 8.5Jx18 front w/ 245-40 and rear was a 9.5Jx18 with a 275-35 tire. That pretty much maxed out the wheel well capacity without body mods.
