E220 differential
Old May 2, 2013 | 11:43 AM
skj0lsvik's Avatar
E220 W210
E220 differential
Hello all,
It seems(sounds..) like my rear differential has decided to break down any minute, a bit early methinks since it's only been working perfectly for 200k miles...
My question is; Does the differential from, let's say, 270 CDI fit? And if yes, would the gear-ratio make any difference?
I am very annoyed by the original differential anyways since it is (IMO) very low geared. When doing 60mph the engine is running very high in the rpm-range, it's doing like 2300-2500 somewhere.
Cheers,
Sondre
Old May 5, 2013 | 03:59 AM
skj0lsvik's Avatar
E220 W210
Ah, darn. That much hassle ehh?
I guess I'll stick with the original gear ratio then!
Thank you once again Plutoe!
