Brake Disc Choice
Old Aug 29, 2003 | 08:18 AM
LewS's Avatar
2004 s600
Brake Disc Choice
I need to replace the front discs on my 2000 e320:
1. In trying to purchase them, there are 3 different ones listed, zimmermann, ATE and one other. Are these just different choices? If so, which is best? If not, how do I determine which one is supposed to go on my car.
2. Is replacing the front discs difficult on this car?
3. By the way, I put Kleen Wheels (to prevent brake dust) on the front and started having brake pulsating a few months later. I can't swear that this was the cause of the disc problem, but anyone considering them may want to think twice.
Old Aug 29, 2003 | 01:20 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Re: Brake Disc Choice
Call Autowerksexpress they have them at great prices
They also can get the crossdrilled rotors
I Have Them Without any Problems on both of my Mercedes
No With Basic Hand tools should take no longer than a Hour
Take The DUST COVERS and Toss them in to the TRASH!
They Will Cause the Rotors to warp under hard driving
I Have seen several do this when I Worked for Mercedes!
Buy Some LOW dust pads...Porterfield,Mintex...etc
Old Aug 29, 2003 | 08:42 PM
hpilot's Avatar
2015 C300, 2025 GLC300 4Matic
Re: Re: Brake Disc Choice
Don't buy Mintex. They squeal, and they are not low dust no matter what they say. I learned the hard way.
Old Aug 30, 2003 | 07:40 AM
LewS's Avatar
2004 s600
Thanks, but are you saying that the brake disc types (ATE, Zimmerman, the cross-drilled that you referred to) are all interchangeable?
Old Sep 2, 2003 | 06:55 PM
rob_fed's Avatar
W204 C300 2010
I went with Brembo replacement rotors from the Tirerack.com.
The only thing hard about taking the front rotors off was the rust that held the rotor onto the hub. A large hammer to the mounting face of the hub loosened the rotor quickly.
Old Sep 2, 2003 | 08:10 PM
E-Klasse's Avatar
W205 C300
I went with the Brembo crossdrilled rotors and ATE pads. You can see them through my wheels. The hardest part was getting the old rotors off like was said before. The heat and the rust sticks the the old ones on.
Old Sep 3, 2003 | 07:42 AM
LewS's Avatar
2004 s600
Thanks guys.
