Loose serpentine belt
Old Jun 5, 2013 | 01:29 AM
pmcd404's Avatar
2000 E320 4matic, 2001 Volvo S80 T6
1997 E300. my serpentine belt tensioner bearing pin, which secures the whole tensioner assembly on a diesel, unscrews itself over time. I am able to screw it back in using vise grips but I'd like something more permanent. The shop manual tells me to remove and reseal the facing before reinstall. I'm assuming they mean Loctite or similar. Problem is, I can't tell what kind or size of tool is called for to screw/unscrew the bearing pin. It looks like large socket of some kind. Any ideas?
Old Jun 5, 2013 | 12:27 PM
pmcd404's Avatar
thanks a lot for the good advice - and your comment about loctite. What does the manual mean when it says 'clean and seal the surface of the assembly' before re-installing? Perhaps gasket compound? Thanks again!
Old Jun 10, 2013 | 07:43 PM
kingbaka's Avatar
1997 E300D
Allen key
17 mm allen is the size.
