Suspension Advice on E320
Old Nov 20, 2001 | 06:04 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Thumbs up Suspension Advice on E320
I just bought an 1998 E320. Previous owner had Eibach springs installed on stock pads. I am looking for an e55 suspension if anyone has a setup for sale. Other recommendations are welcomed too.
thanks
Dan ****
:p :o
Old Nov 20, 2001 | 06:11 PM
Vic55's Avatar
Administrator
Re: Suspension Advice on E320
thanks
Dan ****
:p :o
I have a fully stock E55 AMG suspension- 5k miles on it and in perfect condition- pads really don't matter, you can mix and match for cheap dollars. Send me a PM with your offer, Thanks.
Old Nov 20, 2001 | 06:20 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Post THE SPRINGS
DAN,The springs are the same amg and h/r because on several pdi inspections i found h/r markings on the amg cars...
btw h/r springs will lower your car a little more than the other brand....also you can play with the spring pads for a fine tune
the spring pads are easy to I.D. with the notch/bumps on them
also I have h/r springs with 1 bump spring pads with amg mono blocks 8/9/18 and NO problem with the tires rubbing and it looks
GREAT
Old Nov 20, 2001 | 06:26 PM
Dan Wang's Avatar
Vic,
Thanks for the reply.
Did you change your suspension to the Bilstein/HR combo (similiar to that of the BMW crowd?
Can you or anyone provide details on the differences in suspension from the E320 to E430 to the E55?
I am assuming they are a simple bolt on modification.
Vic, what parts of the suspension are you selling?
Dan
Old Nov 20, 2001 | 06:46 PM
Vic55's Avatar
Administrator
Vic,
Dan
I have the H&R springs that lower the car approx 1.4" up front and 1.3" in the rear. The E55 comes with factory Bilstein Heavy Duty Shocks (HD) and I switched them out for the Bilstein Sports.
I can sell the springs and the shocks. You car will have the same ride height as a factory E55 depending on what pads you have. Like I said before you can mix and match pads but generally you either go the same pad all the way around or a one size smaller pad in the front. I am currently running a #1 pad in the front and a #2 in the rear but before I switched my setup I had #1's front and rear.
Old Nov 20, 2001 | 06:53 PM
Dan Wang's Avatar
Are sway bars different diameters on the E55 and E320?
29mm/19mm?
Old Nov 20, 2001 | 07:46 PM
Mr. Vanos's Avatar
MBWorld Founder
2020 GT R Pro, 2019 GT3 RS, 2018 GT3 Touring
29mm/19mm?
FYI, here are the diameters of the CLK55 and E55 sways:
CLK55
front: 28mm
rear: 18mm
E55
front: 29mm
rear: 20mm
