Brake Wear Indicator/ Speed Sensor Harness
Old Jun 26, 2013 | 08:33 PM
DittyW210's Avatar
1998 Mercedes Benz E320 4Matic
Hello again fellow w210 owners,
quick question. I've got a 98 e320 4matic and my front left wiring harness has torn lining on the wire that goes to the Brake Wear sensor. Now this wire connects to a plug in the wheel well wall that also is the connection for the ABS speed sensor. The part number for the wear sensor wire is 2105405010. My question is, do i need to buy a complete harness or can the wires be changed separately and if so how? It appears to be some sort of spring loaded plug. HELP!
