MityVac 7.3 Liter Fluid Evacuator 7400
For those DYI oil change guys I Strongly recommend picking up one of these bad boys. But get the 7400 as it doesn't have that may pieces that can break. It works very well, I pulled the oil plug and it was bone dry (this is how to properly test if your car is a good candidate for this type of application) Mercedes supposedly uses this method as well for years.
The hardest part was pouring the oil into the jug-
*I also picked up this little guy (loving it) Torque Wrench
Armani
Cheers!
My garage is on a small incline and my car sits pretty low. So this unit works well. Park it in front of my driveway and call it a day-
Armani
I tend to stay with "simpler is better" and hand operated Mityvac work well till friend borrow it and did not return. You need to have space for it in your garage, but you can take the 9l tank directly to recycling station.
I had 1 gallon recycling containers, so my 2nd choice was electric pump. That thing pumps directly into containers and takes less space for storage. Than the electric pump gets messier.
