Time for an Oil Change! By Pelican Parts
Old Sep 6, 2013 | 04:16 PM
PelicanParts.com's Avatar
SPONSOR
One of the most common tasks to perform is replacing your engine oil. Frequent oil changes are perhaps the most important procedure you can do to maintain and prolong the life of your engine. With the better oils that are available today, the requirement for frequent changes is diminishing. Even though Mercedes Benz recommends oil change intervals that are much further apart than in the past, I usually recommend that you keep the changes under the 5,000-mile limit. If you don’t drive your car too often, you should change the oil at least once a year to keep things fresh.
A fresh filter element, fresh engine oil, 13mm wrench, jack stands or ramps, canister for the used oil and some rags and you are set to tackle this project!
Shop for oil and filter element for your W210 Mercedes here.
Take a look at our oil change instructions here.
Enjoy your oil change!
