Issues Starting Your Mercedes? May Be A Bad Camshaft Position Sensor – Pelican Parts
Old Sep 19, 2013 | 11:44 AM
PelicanParts.com's Avatar
SPONSOR
Your fuel injection computer (DME) may output a code that indicates a faulty camshaft position sensor (CPS). This important sensor tells the car’s computer where the camshaft lobes are located in relation to the combustion cycle. The DME takes the signals from the cam position sensor and crankshaft position sensor, and calculates when to fire the fuel injectors and spark plugs. If the camshaft position sensor is not operating properly, your car will run very erratically or perhaps not at all.
Pelican Parts offers camshaft position sensors for your W210 Mercedes. Click here to determine the correct part for your car.
This project should not take you more than one hour. For install instructions, refer to:
Camshaft Position Sensor Replacement
Let us know if you have any questions!
