W210 AC Help
Old Sep 26, 2013 | 09:46 AM
jd_mcse's Avatar
2001 E430
W210 AC Help
Hi Everyone,
First time posting here but a long time reader. I was hopping to get some help on troubleshooting my AC issue. I have a 2001 e430 with 150k miles. A/C reading is as follows:
1. 91
2. 93
3. 98
4. 98
5. 96
6. 191
7. 10-14 (Depends on temp humidity and driving)
8. 107
There are no error codes on the display. I did have the b1416 before but I fixed that issue and reset the codes. I also had the system vacuumed and recharged recently. Any help would be greatly appreciated.
Old Sep 26, 2013 | 02:34 PM
jd_mcse's Avatar
2001 E430
I replaced the Evap Temp Sensor last week with no significant change. the b1416 error returned when I just checked it. The following read I get on the sensors are as follows:
1. 84
2. 89
3. 87
4. 87
5. 85
6. 206
7. 15 (Depends on temp humidity and driving)
8. 120
Let me know if this lines up with your earlier thoughts of either expansion valve and/or compressor.
Thanks for the help!
Old Sep 26, 2013 | 07:40 PM
nelbur's Avatar
1997 E300D
You said you,"had the system vacuumed and recharged recently". Did the system work right after that work was done, and if so how long did it work?
Old Sep 26, 2013 | 09:13 PM
jd_mcse's Avatar
2001 E430
@Nelbur - After the recharge it still did not work. It was left at 2.2 lbs where it was slightly over at 2.6 lbs before.
@Plutoe - During the vacuum & recharge the gauges would fluctuate. The tech said it was acting as if the compressor was bad.
On my way home from work the EC light came on and #7 dropped to a steady 7.
Old Sep 27, 2013 | 10:59 AM
jd_mcse's Avatar
2001 E430
@Plutoe - B1241 and b1416 are the faults. #7 is down to 5 now so the EC light comes on instantly. I'm not sure where this leak would suddenly come from but I will need to track this down before moving forward I suspect. Any other suggestions before I head down this path?
Thanks again!
