What is needed to run E55 rotors on an E320?
Old Oct 8, 2013 | 12:26 AM
siopaolover's Avatar
1998 E320
Hey guys, one hole on my front rotor was stripped by a shop while swapping tires and I was wondering what would be needed to run E55/C43 rotors on our cars?
Old Oct 8, 2013 | 03:44 AM
matt72's Avatar
c124 124.051
calipers ,discs and pads,good luck
Old Oct 8, 2013 | 01:30 PM
1998 E320
so I can't run stock calipers with the upgraded discs?
Old Oct 9, 2013 | 04:57 AM
matt72's Avatar
c124 124.051
i dont think so ,not 100% sure tho. Is it just a case of liking the look of big discs or is it for performance? you could get some drilled and grooved discs that wpuld both look better and work better,without the added amg cost.
Old Oct 9, 2013 | 09:31 AM
illest's Avatar
w210 AMG or S213
the stock calipers would not fit over e55 rotors because they are bigger.
Old Oct 10, 2013 | 10:24 PM
1998 E320
Thanks guys. I'm actually more concerned now about the stripped bolt hole. The shop I went to did not torque my wheels properly, so my bolt hole and bolt were stripped. What's the best way to deal with this?
Old Oct 11, 2013 | 11:02 AM
illest's Avatar
w210 AMG or S213
which hole is stripped, the one for the lugs or the one that holds the rotor on?
Old Oct 11, 2013 | 11:53 AM
1998 E320
One hole for the lugs. Is it an easy fix or do I have to buy a new hub?
Old Oct 11, 2013 | 12:46 PM
illest's Avatar
w210 AMG or S213
One of mine is messed up as well. Depending on how bad it is you maybe able to get someone to tap the threads
Old Oct 12, 2013 | 01:28 AM
1998 E320
oh ok. I notice a little steering wheel vibration but its not too bad. I was thinking of taking a dremel into there and smoothing out the first thread or so, because that's where the problem area seems to be. the rest of the threads in the hole seem fine
