Computer & ECU Question 1997 E320 M104
Old Jan 15, 2014 | 12:21 AM
first210's Avatar
1997 E320
new to forum.
inherited 1997 e320 sedan - m104 engine. had it towed to my place. turns over. does not start.
looked around....the ECU cover was open and the first row of electronics was missing. anyone know what these computers/electronics are?
to be more specific...looking at the engine compartment - the computers in the far left corner covered by an odd shape cover. there are a few rows of computers. the row closest to the front of the car is completely missing...anyone know what was there?
if someone could ID the contents of that entire area, that would be much appreciated. but most especially the front row - that would be great.
if you need more info, let me know.
car is a 1997 E320 with M104 engine.
many thanks. trying to get this thing on the road.
Old Jan 15, 2014 | 10:17 AM
first210's Avatar
1997 E320
VIN: wdbjf55f3va347152
thanks!
Old Jan 15, 2014 | 01:30 PM
first210's Avatar
1997 E320
thanks for the info! much appreciated.
would the absence of the ESP module prevent it from starting (car is cranking) or should i look elsewhere?
I have a code scanner...havent used it yet. any tips or special info i should know before use?
thanks!
Old Feb 1, 2014 | 11:30 PM
first210's Avatar
1997 E320
hi, thanks for the previous posts. i think i have that one. here's a pic. what's missing? anyone know?
thanks in advance!
Old Feb 2, 2014 | 12:34 AM
tee's Avatar
tee
E55,GL 450,Subaru STI,Chevy crewcab
i think its called the k4o relay from what i remember.
Old Feb 6, 2014 | 05:56 AM
rolaes62's Avatar
2001 C320, 1997 E320, 1993 300e & 2005 F150 Supercrew
thanks in advance!
first210, Yup that's where the K40 relay & over load protection board goes. without that your car wont start. you can pick one up on Ebay for around $100 or go to a junkyard, but you have to get one specifically for a 97, a 96 might work but 98 and newer use a different type of relay box. I'll try to post a pic of it for you so you have an idea of what i looks like.
Good luck Rusty
Old Feb 6, 2014 | 05:58 AM
rolaes62's Avatar
K40 Relay & over protection board assembly
Here you go:
K40 Relay & Overload protection board assembly
Attached Thumbnails Computer & ECU Question 1997 E320 M104-1997-k40-relay-board.jpg
Last edited by rolaes62; Feb 6, 2014 at 06:01 AM. Reason: forgot Overload in title
