BBS LM fitment issues for w210
If you run a 265 40 in the rear and a 235/40 on the front, your rear sidewall is going to be a lot thicker than your front. Might want to get the 265/35.
Your front offset is higher, you might have to run a spacer if the wheel/tire hits your upper control arm.
Front: 18x8.5 ET30
235/40r18
Rear: 18x10 ET25
265/35R18
Any opinion valued. Thanks
235. why? because not all 235s are the same. with one brand/model the tire
may barely clear the wheel lip, whereas with another brand/model the lip will
carve into the shoulder of the thread.
if you have the luxury to sample your combo, great. but if you have only one
shot and want to ensure success, you may find yourself having to go with 225s
in the front.
rear is much more forgiving
