Headlight cover condensation
Old Nov 20, 2003 | 02:30 PM
jclemen's Avatar
2003 e320
My 97 e420 is equipped with the xenon's. The passenger side headlight, and inner light both have condensation in them. I was told that there are covers over the headlight/fog light assembly's. Are these easy to get off or do you need a body shop to do it?
Any help is appreciated.
Jeff
97e420
Old Nov 20, 2003 | 02:57 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Re: Headlight cover condensation
Jeff
97e420
Check the Bulb covers...and the seals in the covers first
Are You Going to replace the Lens ?
They can be resealed /replaced using a heat gun to soften the sealer
then reseal the housings using a good sealer
When the Lens is off Inspect the lens to be Sure its not cracked
causing a leak...
Old Nov 20, 2003 | 03:42 PM
jclemen's Avatar
2003 e320
This is what I need help in. Not sure what's involved here. My guess (hope) is that the condensation is between the cover and the lens, if that's the way it's setup.
Jeff
97e420
