problem with brakes
Old Dec 3, 2003 | 12:52 AM
Alexbenz's Avatar
Sean's Sister--
problem with brakes
i changed out my rotors to the cross-drilled ones and also got my pads changed to those ones that reduce brake dust and now when i brake there's some weird noises, seems loud, grinding and also my steering wheel moves a little if i brake hard..... could it be the rotors????? i only put 400-500 miles since i changed them.....
Old Dec 3, 2003 | 03:50 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Re: problem with brakes
You Will hear Air passing through the Drilled rotors..I Hear
It on mine. More so from the rears...
It Sounds Like You warped the brake rotors.
Did You break the Pads/rotors in....NO Hard stops for 100 miles?
The Steering Wheel Vibration is a Sign of warped rotors when the Brakes are applied....You Can Surface drilled rotors on a Mill
But Your dad has a shop....Im Sure He will fix the problem
Old Dec 3, 2003 | 05:07 PM
Alexbenz's Avatar
Sean's Sister--
i was thinking the same as well, i tried, there were a couple of hard stops due to weather conditions... thanks for the heads up, i'm going to take it there and see what happens
Old Dec 3, 2003 | 09:04 PM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
what kind of pads?
I changed from pagids to porterfields,,and was very careful to baby them for 300 miles as recommended.It does make a difference.
