Passenger side highbeam wont light.
Old 05-04-2014, 11:45 PM
Dnasty's Avatar
2010 e550 coupe
I got the intermittent warnings for the highbeam then it finally went out so I assumed it was a bad bulb like I had on the drivers side. I put a new bulb in and i get no light. Does anyone know what could be the cause the driver highbeam still works so it can't be a fuse issue can it? Another thing i noticed is that the passenger bulbs sit differently than the drivers when I change the drivers i just pull it out and put it back in the passenger bulbs have these metal clamps holding each one in do they need to be in a certain way for the light to power?I have a 98 e320 btw
Old 05-05-2014, 10:13 AM
Plutoe's Avatar
Received 1,048 Likes on 970 Posts
1999 E300TD
Look to the side that works and insert the bulbs in the same manner!!
Old 05-05-2014, 08:33 PM
Dnasty's Avatar
2010 e550 coupe
Old 05-06-2014, 02:13 PM
GregMN's Avatar
'87 190D, '96 E300D (2), '07 ML320 CDI
check your fuses. I think that there is a separate fuse for each side.
Quick Reply: Passenger side highbeam wont light.
