What is the bushing called?
After inspecting my front brakes, I also notice that these bushings need to be replaced. Are they the subframe bushings? I just refer to them generically as swaybar bushings.
Thanx Mark..
Are these split at some point so that they may be slide on at that spot once the bracket is loosened, or must it be slide all the way along the sway bar?
209/W210 Estate /W211 modded by MBENZNL
Im NOT 100Percent sure but I Think That they are NON Split
I Remember that from doing the E55 sway bars on my W210
It Will Help to Use a Good Silicone or Paste lube..
