Extremely loud brake squeal on new pads.
Old May 17, 2014 | 11:40 AM
Dnasty's Avatar
2010 e550 coupe
I just installed some new bosch quietcast pads on my e320 and they squeal like no brakes ive ever heard before upon each depression of the pedal. Ive done pads many times in the past so i'm used to a little set in time on pads for the squal to go away. But this is such a prominent squeal I think I may be pulled over by a cop. I just installed these about an hour ago mabye i'm being a little over cautious but has anyone had any experience with this?
Old May 20, 2014 | 11:15 AM
bige55amg's Avatar
97 C280, 99 E320wagon, 00 ML55, 01 E55, 02 G500 Gone but not forgotten.Curr.97 S320, 2000 E320 wagon
I installed the same Bosch Quite pads and rotors. So far I've put 7000+ miles with no problems. I was going to just turn the rotors and replace the pads, but I didn't want to take a chance mixing pad and rotor manufacturers. (installed on 2000 E320 Wagon)
Old May 22, 2014 | 02:44 PM
Dnasty's Avatar
2010 e550 coupe
I've been monitoring the brakes for a few days to see if the squeal would stop which it didn't but I pinpointed it to the driver front pads all the other pads seem to be making no noise. I took them out cleaned em reset them and still the squeal. I ordered replacements but is it possible that u can get one set of defective brake pads?
Old May 29, 2014 | 01:02 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
This might be a dumb question, but did you resurface/change the rotors?
Old May 29, 2014 | 02:40 PM
Dnasty's Avatar
2010 e550 coupe
No I did not resurface or change the rotors. In fact when I took my car to my benz mechanic he was only going to change the pads and said the rotors are fine and his standards on that stuff are much higher than mine.
