Door's won't close
Old Jun 10, 2014 | 04:00 PM
firmas2010's Avatar
w210 E300 TD
Door's won't close
Hi guys,
I have E300 TD, and recently my car wont close or open the doors, either with the keyfob or with the console switch.
This is strange because the turning light works when i press the button on the keyfob (to open or to close). The car works normaly with no other trouble.
What can it be the problem?
Old Jun 10, 2014 | 08:00 PM
Fabio D's Avatar
210 55
PSE unit is the most common, under rear right seat, is a vacum pump, check all the fuses first, if thei'r fine check if you dont got water inside the pse unit
Fabio Daniel
Old Jun 16, 2014 | 04:45 PM
firmas2010's Avatar
w210 E300 TD
i don't see any signs of water now, but i found rust. Maybe it's a sign that was water before. I had checked the fuses and i think it's all ok.
The strange part is that besides the facts that i presented before, the car works just fine.
if i change the vaccum unit, do the car need some programing??
Old Jun 16, 2014 | 04:47 PM
firmas2010's Avatar
w210 E300 TD
i also forgot to mention that the back head rest doesn't come down :S
Old Jun 17, 2014 | 04:40 PM
firmas2010's Avatar
w210 E300 TD
anyone?
Old Jun 18, 2014 | 08:25 PM
Fabio D's Avatar
210 55
Yup, you have a bad PSE unit, control the back headrest too
If you have rust, check the inside electronics of the PSE unit, open it and check it
Also, before install a new/used PSE, close the car with you inside (remove the rear seat) and other person spray the car wit lot of water to see if you got any leak inside
Yes, they need to be programmed with your car specifications
Fabio Daniel
