Vanity mirror light
Old Dec 11, 2003 | 04:13 PM
Brozyniak's Avatar
E430
Vanity mirror light
One of my bulbs has gone on the passenger side vanity mirror - wife's been overusing it lol.
Does anyone know how to change it - i can't seem to see how to get inthere.
Cheers
Old Dec 12, 2003 | 01:32 AM
Benz's Avatar
2000 F-150 XLT Sport Crew Cab
Girls tend to do this LOL....I never learned how to change those...I dont know if you even can . Check the wires from both ends to make sure they are hooked up correct....I will check out my car and see if I have any luck for ya....Tell her to start using her compact lol
Old Dec 12, 2003 | 08:50 AM
Brozyniak's Avatar
E430
It was working fine a while back. First thing my wife does when we get in the car is pull down the mirror and check her make up. It's a bit annoying as it reduces my visibility just as I am maneouvering out of the drive
Old Dec 20, 2003 | 07:05 PM
gmacosta's Avatar
96 e320
I changed my bulb in the vanity light in 5 seconds. no screw or nothing. All I did was open the vanity flap, and by the flap give it a QUICK tug! I was hesistant to do this cuz I thought I would break it, but that's all to it, replace bulb and your done.
Old Dec 21, 2003 | 12:33 PM
MBZ12's Avatar
'07 R350. '05 C230. '93 454SS Truck. '71 Chevelle SS.
Re: Vanity mirror light
Funny thing...mine went out at last night on the driver's side also. Wifey MUST be using it too much. In the year and half that I've had my car, I swear I have only flipped my driver's side vanity mirror once!
Old Dec 21, 2003 | 01:02 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Had the same problem with my 01 E320 4M. Dealer took care of it and it turned out to be a bad switch that turns the light on when the visor is lowered. Took about 30 min at the dealers
Old Dec 21, 2003 | 07:13 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Check the Contacts on the Sun Visor ..where it snaps on...
The contacts get worn and you can clean the contacts
also try Pushing the Visor further towards the windshield
That will tell you if the contacts are worn..
The bulb can be replaced if its defective
