Finally slammed the bich (pics)
Old Aug 10, 2014 | 12:01 AM
Brodie320's Avatar
1995 Mercedes E320 sedan
After being absent from the forum for around 2 years i decided to post a pic of my car after i lowered it. Unfortunatelly it seems to sit about 8mm lower in the front right, it was like this before lowering also. Anybody got any suggestions as to what could be causing this? Or had the same problem?
Bad quality phne pic
Old Aug 10, 2014 | 10:42 AM
illest's Avatar
w210 AMG or S213
are you running the same size spring pads on both sides?
Old Aug 10, 2014 | 02:16 PM
Brodie320's Avatar
I am not running pads at all, these are a new zealand made spring which is made to be run without the pad, even before lowering it sat lower in to one corner
Old Aug 12, 2014 | 01:10 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Mine was like that too. Sat about 4-5mm lower on the passenger side. My solution was to get divorced and get a skinnier girlfriend.
Nah jk, I just got coilovers and adjusted it later. Id use a small spring pad if you can...but id be kinda worried about one side sagging that much...is your perch ok?
Old Aug 16, 2014 | 09:32 AM
GregMN's Avatar
'87 190D, '96 E300D (2), '07 ML320 CDI
Check the spring perch.
Old Aug 16, 2014 | 05:20 PM
cudaized's Avatar
2002 E55 AMG Obsidian Black with Charcoal
X 2
See if the bottom of the spring perch is horizontal.
Old Sep 3, 2014 | 08:47 PM
Lowflyer's Avatar
2012 C250 Coupe, 2017 C43 AMG Coupe
Damn, all this time trying to find the source when all I had to do is kick the b:;() out! Thanks for the help..... Lol!
