chip tuning
thanks for any input.
bkc
If all you need to do is reprogram some software, why wouldn't the manufacturers do it?
Do they work by increasing performance at the expense of something else, like gas mileage, emissions, reliability, or what?
Or is this all a bunch of snake oil?
One thing is for sure though. Replacing the chip will definitely be detrimental to your factory warranty.
In any case to answer your question, yes these chips DO work, but they do come at some expense. How major or minor its hard to say. The chips usually take advantage of a safety gap the manufacturers leave in the timing, air fuel mixture, turbo boost pressure, etc. Maybe the maximum tolerance before your turbo breaks is 19psi. The factory probably has it at 14, and the chip will make it 18. It definitely will put additional strain on your vehicle, but how much strain, depends on how aggressive the chip is.
Many mercedes diesel owners and VW diesel owners swear by a chipping company called Upsolute.
Some mercedes already have high compression, around 11:1, and it is hard to imaging that it could be modified substantially.
A Tahoe may be a different story, usually they are lower compression big V8s that run on 87 oct from factory.
Moral of the story, it depends on how detuned the car is from the factory. I later found out that there is a european version of the S4 which has just about the same numbers for torque and HP. as I got as a result of the chip swap. I guess they don't think we can handle power here in the US!!
joeyharp
those gains are virtually unheard of, i've never seen any chip company boast more than 35hp gain. I admit i've never heard about audi chips tho. Thats unreal if you're not bsing about those numbers of course
nowack page, click on ecu tuning for all specs
joey:
did you leave your s4 suspension stock? when i had that car the handling was my largest peeve. with the chip i'm assuming the suspension is a little overwhelmed, especially with the p7000's. or at least that was my experience. also what colour, i had imola yellow.
I had a silver s4...Like everyone else but you!! My dealer couldn't find a yellow one or I would have been all over it!
As to the question someone else asked of my b.s.-ing about the torque and hp jumps after chipping the car... I am certainly not. If you don't have any experience with turbo cars, I can understand the doubt.
joeyharp
