Battery Repacement
Story:
Ive been starting her up every morning and the battery seems weak, barely starting her up. she's fine all day.
If i let her sit more than 24 hrs i need a jump. It won't be completely dead, just not enough to get her started.
So i decided to just get a new battery. Can i replace it with any battery? if not which one is best? or are there other alternatives?
Thanks in advance~!!!
Plan on a $150 replacement, but that will get you a good number of years in my experience.
Good luck.
MB dealer battery is about $170 installed onsite which includes old battery disposal and resetting any convenience features which have lost sync. Also, entitles you to 18 mos of roadside assistance and the technology is matched to your car. With good care (check the electrolyte level periodically) it should last 6-7 years.
Aftermarket battery is about $100 and should last 3-4 years.
You do the math.
You do the math.
which can be repaired and will quickly drop a bundle on a new replacement.
If it is a lead acid, flood cell design, pop the caps off and check to see if the
fluid level is low. If so, fill to top of plates with distilled water. then, place
on 10 amp charger overnight. may even need 2 days of carefully watched
charging.
If no-maintenance, flooded cell design, you may not be able to remove the
caps, though sometimes you can carefully pry off and go through same review
as above.
If AGM spiral wound, same as AGM flat plates - only option is to try charging
If lithium variant, check with the cell's manufacturer as it can get complicated.
Check also with your employer. If they have an account with Interstate, et al,
you may be able to ride on their coat-tails in respect to their corp discount.
My employer uses Interstate so I can pick up 900 amp/hr replacement for $50
http://shop.advanceautoparts.com/p/a...253/10720898-P
