need rear exhust tips like this....
Old 01-11-2004 | 12:54 PM
Alexbenz's Avatar
Sean's Sister--
since i can't post pics here, check this out.... dealer was no help, where can i get the amg tips like this and if not amg then something that looks close to it?
http://benzworld.org/forums/forums/t...posts=1&fid=17
Old 01-12-2004 | 12:34 PM
Whitey's Avatar
98 W210 Advantgarde
Those look like extensions for the bent OEM pipes. Did you want ones for the straight ones?
Old 01-12-2004 | 05:39 PM
Alexbenz's Avatar
Sean's Sister--
I GUESS, I WANT IT LIKE THE PIC, THE CL55 TIPS..... I'M OPEN FOR ANY IDEAS....
Old 01-12-2004 | 08:49 PM
Whitey's Avatar
98 W210 Advantgarde
I've seen the exact same ones for our cars but they're for the bent OEM tubes not straight......unless you wanna go back to stock exhausts....Ok, let me do a search around town for ya and give you a brand in case they have them where you are. In any case I know of a place that makes them here. At this rate, it may be worth coming over just to bring you guys some belated/early Chrissie pressies...
Old 01-12-2004 | 11:32 PM
Spinman's Avatar
'97 E-320 26k miles '91 500SL 26k miles
Hey Alex,
I believe I saw something similar and of excellent quality at the Benz dealer in Washington, Pennsylvania ( 25 miles south of Pgh.) while in for service. I was impressed with the quality of the exhaust tips and inquired as to cost and brand. Was told $300.00 per set. There are two outlet tips per unit. Therefore, the cost for duals would apparently run ya $600 scooters. The brand name is Schatz, a German firm. I've seen a few of their things on Ebay. Again, the quality is top-notch. The dealer's name is John Sisson Mercedes. Their number is: 724-206-6000.
Spinman
Old 01-12-2004 | 11:38 PM
Whitey's Avatar
98 W210 Advantgarde
Confirmed, Schatz is top notch.
Quick Reply: need rear exhust tips like this....
