E430 spark plugs, which ones?
I did a search here first and cant really tell which plugs for the E430. NGK 7090 seems to be the most economical, but are they the right plug? Most of the posts on here are for E320. Thanks!
2001 E430, 2002 ML55
Double check my answer cause I'm not 100% sure. Amazon and Autohausaz says it's good for the M113.
http://www.autohausaz.com/pn/BKR5EGP
You can use ngk 7090 plugs or bosch 7422 (also known as FR8DPP33). If your going to a parts store the NGKs are probably more readily available and actually theyre less expensive. I bought my Bosch plugs online for about 5 bucks. You'll need 16 of them. There's a special wrench that makes pulling the wires off the plugs much
easier.
easier.
