96 E 320 FRONT CRANK CASE SEAL REPLACEMENT
Old 04-08-2015, 03:26 PM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
I just bought a 96 E 320 with 159 k it needs front crank case seal
I am going to be doing the job myself
Anything special I need to know will it be much different from any other crank case seal replacement ?
Does any one also know what size the socket is on the pully ?
Will I need any special tools , special socket to get the seal in is it really needed ? thanks
Old 04-09-2015, 07:24 AM
vinceC's Avatar
2014 ML350 4Matic
The bolt is 27mm. The torque for the bolt is either 400Nm/295 Ft. Lbs. (if the vibration damper has four dished washers) or 370Nm/273 Ft. Lbs. (if a conical washer is installed instead of dished washers).
Old 04-13-2015, 08:46 PM
Thank you Vince the guy had backed out of the deal at the last second but im sure this information will come in handy in the future
Quick Reply: 96 E 320 FRONT CRANK CASE SEAL REPLACEMENT
