2002 E320 Direct Fit Catalytic Converter Replacements
Old Jun 1, 2015 | 02:28 PM
p1701's Avatar
E320
After reading so many threads on catalytic converter replacement, I think for my situation direct fit cat replacement would be best. There are several systems available on the market costing between $500-600 or so per side. My regular mechanic will install them. For the E320 4D Sedan RWD owners that have used direct fit cat replacements, my questions are:
- What system did you use?
- Part numbers?
- How many miles since replacement and any problem so far?
One owner of a 99 E320 wagon had very good results with system from Autohaus. Any other experience from E320 sedan RWD owners?
Many thanks in advance.
Old Jun 4, 2015 | 01:45 PM
nsx78's Avatar
You may want to check with your dealer. I recall them having remanufactured factory cats for $300-400 per side after core exchange.
