99 E320 Lowering Help
Old Mar 4, 2016 | 11:42 AM
Asa Hubbard's Avatar
1999 Mercedes Benz E320
Exclamation 99 E320 Lowering Help
I need help getting my 210 lower. I want to avoid buying coils because I do not feel like paying 1k. I am currently running B&G Racing Suspension which adds a 1.6 inch drop all around (allegedly.) I want to get much lower. Im open to cut springs but I just do not know how much goes into that like what all needs to be changed (if any), or the best way to cut the springs. Anything will help as far as ideas. For some reason I could not attach any images due to a security token error. My instagram is @themrhubbard if you would like to see my 210.
mod list: 18' AMG Mono Blocks, straight pipe from the cats back, hardwood floor trunk, 25% tint, aftermarket rear bumper, & dual tip exhaust.
Old Mar 4, 2016 | 01:49 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
Did you try changing out the spring pads as well? Changing my pads from 5 to 1 lowered the car another inch.
Cutting the coils is ok. The way that our springs sit on the perch just make sure everything lines up and cut away. I used a dremel with kevlar reinforced wheel on mine. (this was before i got coil overs)
