Modified Air Box
If yes email me at geo3617(@)gmail.com if you're interested in buying one. You also have the option to send me your air box and save 80.00.
What I do is make the air box taller to breathe better. And I remove all the square baffles from inside the air box for smoother and less restrictive air flow.
After I do the work on the air box it will be like the Renntech air box minus the carbon fiber and minus the price that it sells for. The Renntech box goes for like $1500 plus your box.
I'm charging $525.00 shipped to your door.
Custom air boxes have shown 10HP and same with torque. I made one for myself and honestly loved it. So I decided to make more for those interested. I will upload some pictures later.
Notice the oem how low the top plastic is in the front where the air flow sensor hooks up. After modification it's about 4 inches taller! The hood does close perfectly.
So now I leave the strips of plastic that go the same direction as the air flow.
I get rid of the small plastic ones which than takes away the square to leave the longer ones to direct air. Hope that makes sense.
My 320 in W211 body has one of those big boxes, what I think gives less restriction than older box with single filter, but there is no way I can measure the difference if such exist.
In my teen years my hobby was flying models and one of the first engine modification was polishing the intakes, what did make noticeable difference from sand-cast aluminum passages.
But those were miniature engines that could pump close to 1 HP from cu cm.
Comparing to 3,000HP from 320 engie
Soon there will be a user review, hopefully by next week.
Heres some pics that show how to remove that cover.
Not sure why Mercedes made it so large but imo it's not needed. Modification to this shroud can be done to not have it dip so low into the engine bay.
I'd like to test the box compare to the stock one on a dyno. Assuming it's similar flow wise to the renntech CF airbox, this would be a great upgrade while retaining the stock look when opening the hood! Personally I don't like the look of carbon fiber :p
Not trying to debate with you. Just sharing a solution for performance gains.
I have come up with a solution to make your cars go fast and smooth. You guys just need to think how to go around these small obsticles. The power is so well worth it!
http://www.ebay.com/gds/How-Will-a-P...7633507/g.html
I did have to remove the hood panel in order to close the hood for the test drive. In full disclosure I'm not willing to modify the panel to get the box to fit, so I sent the box back to speed43 today. I do think he is on to something with his modifications. I'm looking forward to dyno results. He is willing and capable of making modifications in order to make this work. So if you're interested, I would contact him to discuss your options.
