Torx
Old Apr 11, 2016 | 09:26 AM
Wess's Avatar
2000 E 430
Torx
Tried searching for this and couldn't come up with an answer. Can someone tell me what size torx socket I need to remove my CPS from my 2000, E430? I left my set at my other house, 1100 miles away, and I need to go buy a single socket to replace the CPS. Thanks!
Old Apr 11, 2016 | 01:24 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Socket would make it E wrench, when I believe you need T15
Size might change from model to model, so I would invest $7 in whole set. You will always find it handy again.
http://www.harborfreight.com/3-pc-sa...set-60822.html
wise grip, or cutting a notch with hack saw works in emergency.
Old Apr 11, 2016 | 04:04 PM
kajtek1's Avatar
Evidently Plutoe never work on one, but on V8 engines top access can be impossible and then you need to go via wheel well.
Again, each model can be different and I never owned E430.
Old Apr 11, 2016 | 06:26 PM
Wess's Avatar
2000 E 430
E8, 1/4 drive with a small extension did the trick, thanks for your replies.
