BAS/ESP/ABS lights, vehicle won't start
Old Jun 7, 2016 | 12:03 PM
Wmorrison67's Avatar
2000 E320
Hello,
I have a 2000 E320. My wife was driving the vehicle last week when she stopped to make a left turn, the dreaded bas/esp/abs lights visit workshop lights came on. She pulled into a parking spot, turned the vehicle off, and attempted to restart the vehicle but it wouldn't turn start or shift out of park. I had the vehicle towed home and consulted other forums on here. I found the brake stop switch could be the issue. Today, I replaced the brake stop switch and the vehicle still does not operate.
I hope someone can help me diagnose this problem.
I replaced the front brake pads two weeks ago and changed the oil other than those two pieces of maintenance nothing else recently has been done to the vehicle.
I did not replace the brake pad wear sensors. Could this be the problem?? I would hope that complete shutdown of the vehicle would not be caused by the brake pad wear sensors.
Thanks in advance for any help or suggestions for this problem.
Old Jun 7, 2016 | 05:02 PM
fabbrisd1's Avatar
A gaggle of MB's
I would not call this "sky is falling" like Bluto..
I would suggest the battery might be failing/failed to provide enough juice for crank.
With key out of the ignition - pull the battery - clean terminals including ground strap - and have battery tested.
Make sure you have radio code and reset procedures in hand (radio, steering angle, each window, sunroof) when battery is reconnected - again key out of the ignition when reconnecting the battery.
Keep the beat !
Old Jun 7, 2016 | 09:32 PM
2000 E320
Thanks for the replies to my issue so far. I pulled the battery today and took it to be checked. I was informed that the battery is 100% charged. It it fairly new having been replaced in April 2015.
Old Jun 8, 2016 | 08:59 PM
fabbrisd1's Avatar
A gaggle of MB's
Blutoe... I understand you are trying to be helpful.. and so am I.
You know that multiple warning lights are commonly sign of failing battery.. and it's good to get that out of the way.
If it way me - I would recheck the brake light switch install - good "sticky" on that on benzworld.org forum - I am not a fan of the non-MB/knockoff switch - if genuine Mb switch recheck install.
Keep the beat !
Old Jun 9, 2016 | 08:33 AM
2000 E320
Thank you both for your comments. I will recheck the brake light switch install as I did used a non mb switch for replacement. I also bought a Obd reader yesterday which didn't tell me much other than the abs couldn't be read. I love my 320 just find it hard to believe that a sensor somewhere won't even allow me to start the vehicle.
