More tail light bulbs???
I'm not talking about the normal rear break lights mounted on the outside body but the red lights on a 96 E320 above the clear reverse lights which are both mounted on the trunk not to far from the license plate. The left side has a bulb and the right side does not. It has a stock plastic piece to cover the hole. I've tried stepping on the breaks, etc, etc. and it doesn't light up. (Though it did one time which we were unable to recreate.) Question is what are the lights for and what do I do about the right side which has a plastic piece? Thanks.
You're supposed to only have one. If you had them on both sides, it would look like you had your brake lights on.
I turn my on only when in thick fog. I don't understand the people who drive with it on under normal driving conditions.
LHS car will have the bulb on the left hand side, and vice versa for the RHD cars.
it's an Euro requirement, since LHS and RHD cars mingle in Germany (from England RHS to Germany LHS) and people can highlight to other drivers the type of cars they're driving.
Do you mind if I ask where did you purchase the 18" AMG wheels, and how much did you pay for it ? Do you change the suspension/shock ? How's the ride quality compare to the original 16" ?
You can connect both sockets up and put bulbs on both sides. You can use them all of the time if you put lower wattage bulbs in the sockets. Otherwise it looks like you brake lights are stuck on.
They are great to turn on when you have someone tailgating you for no apparent reason. The glare alone causes most drivers on your butt to back-off. Although there are those persistents ones
