Shopping for shocks
Old Jul 24, 2016 | 10:38 AM
wasp01amg's Avatar
2001 E-55 AMG
Shopping for shocks
My 2001 E55 has 114,000 miles and rides like a truck. I'm shopping for new shocks and OEM or equivalent. Where can I get reasonably priced units. I've seen a wide range in price. What confuses me though is how much more the front OEM or Bilstien shocks are than the rears. What's up with that. I'm not building a track car so adjustability is not needed. I just don't want my teeth jarred when I hit a bump.
Old Jul 24, 2016 | 11:32 AM
Beverly Sharp's Avatar
E430
shocks
Teeth jarred? Then don't buy Bilstein heavy duty shocks. Consider OEMs or Sachs Boge. I'm very happy with the latter.
James
Old Jul 24, 2016 | 07:04 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Bad shocks would ride more like a boat.
What size tires you have and pressure?
Old Jul 24, 2016 | 08:27 PM
wasp01amg's Avatar
2001 E-55 AMG
Stock sized run flats at name plate pressure.
Old Jul 24, 2016 | 09:31 PM
kajtek1's Avatar
What is stock on AMG? Aren't run-flat famous for harsh riding?
I had to sell ML55 AMG pretty cheap because even I liked the performance DW could not take truck-like riding.
Can't have it all.
Did you do push-test for shocks?
Old Jul 24, 2016 | 11:26 PM
fabbrisd1's Avatar
A gaggle of MB's
A 2001 E55 - OE spec tires are not "run-flat" - so you might recheck your tire info.
The OE/Bilstein's with AMG stickers will run well out past 200K miles - I suggest you re-examine tires - Yokohama makes a affordable tire for your E55 - and have the bushings on the suspension looked at by a competent indie.
Old Jul 25, 2016 | 09:33 AM
wasp01amg's Avatar
2001 E-55 AMG
Car has had run flats for as long as we can remember. Bridgestone Potenzas RFT, 41 psig front and 48 rear. These are the pressures recommended on the door label. The label on the gas cap ranges from 32 to 48 dependent on load and speed. All replacement tires came from dealership in Walnut Creek where family always had maintenance performed. Current tires have 10k miles and still in excellent shape. Guess I'll have to live with harshness when I hit bumps. ill try the lower pressure range and see if that makes the ride acceptable.
Old Jul 25, 2016 | 10:54 AM
kajtek1's Avatar
My gas cap says 28/32 for low load and speeds below 100 mph.
48 psi sure sounds like truck tire.
So you live in Houston area and have car maintained in WC, California?
Old Jul 25, 2016 | 11:08 AM
wasp01amg's Avatar
2001 E-55 AMG
I've moved. Last dealer service was in wc. I went down to 32/33 per gas door, low load below 130km, sticker for E55 AMG.
Old Jul 26, 2016 | 01:17 PM
wasp01amg's Avatar
2001 E-55 AMG
Got to drive it with 32/33 pressure in tires today. Much smoother ride. We will see if tire wear changes. No need for new shocks. Thanks for pulling my head out of my ***.
Old Jul 27, 2016 | 12:21 AM
fabbrisd1's Avatar
A gaggle of MB's
Glad tire inflation pressures have gotten you back off the edge.
Next time you come up on tire replacement - as long as you have the MB OE spare tire - I suggest you consider dropping the RFT (run flat tires) .
Gives you much wider - and frankly lot less expensive - like Yokohama Advan - or Kimho Ecsta 4X in "affordable budget" range - or the great Pilot A/S3+ for price of the RFT...
As you can tell the RFT are far/far from my favorites..
Old Jul 27, 2016 | 02:25 PM
wasp01amg's Avatar
2001 E-55 AMG
Spare is present. RFT not on the menu for me any longer.
Old Jul 27, 2016 | 09:43 PM
kajtek1's Avatar
Owning lot of toys, including backhoe tractor I learn how to fix nail holes.
Technology improved and latest "strings" are pretty good. $6 for a dozen with tool and I had to use it this week as our "beach run" on Saturday come with flat tire on Sunday.
Took me about 15 minutes to take the wheel off, find the metal junk (strange flat piece) and insert the plug with inflation (have compressor under the pressure in my garage all the time).
Driving pickup with 6-wheel trailer I was also carrying Firestone 12V compressor, that would pump 90 psi tire in "some" time
Never felt need for RFT.
Old Jul 28, 2016 | 09:05 AM
wasp01amg's Avatar
2001 E-55 AMG
I to have repaired tires with plugs. Living on the gulf coast during/after hurricanes you pickup nails and learn to repair tires. Yes, I have lived in many different places.
