Climate Control LCD
Old Oct 22, 2016 | 01:54 PM
Fspectrum's Avatar
2002 E430 4MATIC
Climate Control LCD
Hi all, my climate control lcd back light is fine but the lcd display driver side is off a bit. From what I have gathered so far is this may be something I cannot fix and only swap for another climate control unit. Is that true a new bulb will not fix this? As you can see in the pic the "F" is not fully displayed. Just making sure the new bulb will not do the trick before considering trying to find replacement unit. Thanks.
Old Oct 22, 2016 | 05:26 PM
fabbrisd1's Avatar
A gaggle of MB's
You are correct - you have "missing segments" on the display - and YES you can replace with another used climate control WITH SAME PART#.
You can pull the unit- and get the part # from the Mercedes label on the unit.
Keep the beat !
Old Oct 22, 2016 | 05:55 PM
Fspectrum's Avatar
2002 E430 4MATIC
Thank you for the confirmation, very appreciated.
Old Oct 23, 2016 | 01:36 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Those things run pretty cheap and if you let me know before Monday, I can pull climatronic from junk yard for you for minimal charge.
