Possible dead computer modules
Old Oct 27, 2016 | 11:22 PM
Serge933's Avatar
2001 Mercedes E320 2010 Volkswagen CC 1998 BMW 740iL 1989 BMW 750iL
Hello everyone,
New here, but been using the forum as a resource for some time now.
I have this problem on my W210 where the BAS, ESP, ABS, and SRS lights are all on. This all came up after a friend of mine accidently put in a new battery backwards. This blew the fuses for the Command and Bose amplifier. I took care of that but the climate control backlights are dead.
I took it to one of my indy mechanics and he attempted to connect his diag PC to the failing modules, and it returned with a failed to connect message, stating that the car electrics were not on.
I know those lights apart from the SRS are usually attributed to a bad brake light switch but that was replaced just before this happened and double checked after the whole situation.
What do you all recommend I start with? Are these modules easily swapped? Or do they need to be recoded? I unfortunately cannot source any wiring diagrams to check for proper signal and voltages. I come from a large background with older BMWs, mainly 80s and 90s 7 series and there is a plethora of info on those cars, not so much on these, at least by what I see.
I would like to swap these modules out but cannot find if they need to be recoded, reprogrammed.
Thanks in advance.
