Steering knuckle/spindle replacement
Old Feb 24, 2017 | 09:49 AM
timmins's Avatar
1999 E55 AMG
Hi there, hoping to get ideas about how to tackle this job:
W210 E55, passenger front wheel bearing collapsed while I was driving along, with absolutely no warning! Stripped it down and found the race has firmly attached itself to the spindle. Even if I can get it off, changes are the spindle will be scored.
Long story short, I need to replace the spindle/knuckle assembly:
https://www.fcpeuro.com/products/mer...amg-2103300020
It looks straightforward enough - I assume I need to jack it/support it by the control arm, then I can undo the top bolt, tie rod end and lower ball joint.
Anything I'm missing?
Thanks in advance!
