COMAND - hidden menu - pls try it and send me the info
2004 SL55, 2015 A250d, 2016 GLC250d
Hi
Im trying to collate info on software versions of COMAND in Europe and USA
So, if anyone would like to help, can U do this
Enter the hidden diagnostic mode on COMAND
- Select AUX input mode [press SYS button, select AUX from menu]
- Hold down Mute , 1, 3 all together
- Menu appears with "Processors" "Tuner" "Diagnostics" and possibly "Configuration"
Select Versions
Select Processors
collect FIS and S/W info
Press RET [goes back to Versions menu]
Select FIS
collect FIS, S/w and H/W info
[for those in the US, can you go back to the Versions menu, scroll down and see if you have a TV setting ??]
Heres what I have so far
MY2001 European COMAND from E Class
From Processors menu
FIS: Apr 4 2000
S/W Rel_V13.06
From FIS menu
H/W 11.0
S/w 14.0
Production Date 04.08.00
MB nr 210 820 54 89
MY2000 European COMAND in CLK55
Processors:
FIS Oct 8 1999
S/W 8.17
FIS Menu:
H/W 45.99
S/W 40.99
Production Date 09.05.00
MB nr 208 820 37 89
Select Versions
Select Processors
Select FIS
FIS: Apr 4 2000
S/W Rel_V13.06
From FIS menu
H/W 11.0
S/w 14.0
MB nr 210 820 54 89
Processors:
FIS Oct 8 1999
S/W 8.17
FIS Menu:
H/W 45.99
S/W 40.99
MB nr 208 820 37 89
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
2001 USA COMAND (v2.5) from CL-Class
FIS: Nov 23, 2000 12:51
S/W Rel_V06.23
From FIS menu
H/W 01.01
S/w 47.00
Production Date 19.04.01
MB nr 220 820 49 89
No TV setting, however in Config screen there is a box that is unchecked labeled "TV-TUNER"
S/W Rel_V06.23
From FIS menu
H/W 01.01
S/w 47.00
MB nr 220 820 49 89
