Door Locks not working
It makes it challenging to understand what you're attempting to describe,
requiring backtracking and rereading.
Making a stab, did anyone spill anything inside the car, or leave the roof open
during a rain spell? Have you thought of looking under the rear seat an into
that target rich environment filled with critical components to see if there are
any signs of moisture which may have shorted some of the electronics or the
PSE pump?
and clean fix. and yes, definitely clean all the relays and fuses individually.
don't skimp and just spray the whole cluster without performing a continuity
check on each fuse as sometimes it is possible for the fuse to blow but it appears
intact.
if you're able to see a water line on the side of the PSE pump foam, or on the
battery, it may give you a clue how much water entered ... thus, which
components may have been affected. r-
