2001 E320 Limp mode
2) PO410 has nothing to do with limp mode - it is a minor code for another system
3) PO700 - I might suggest your do a forum search - buy a $9 can of MAF cleaner - and pull and clean the Transmission Control Module - contamination there could be the reason for the code - if that doesn't clear it up - you may need to have code cleared by Star..
If you had fluid at the connector - then over time the fluid "wicks up" the harness to the TCM (tranny control module_ in the engine compartment - where that fluid can contaminate the connector or the actual TCM board itself.
If that is the case - good news 98% of the time the TCM can be cleaned/recovered.
Search the forum - find where/how to pull the TCM board - clean the connector inside that box with spray - let air dry (no heat).
With the board out - holding board on edge - "flood" both both sides of the board with MAF cleaner - objective is to let the contamination "run off trhe board - let air dry - no heat - then reinstall.
Sometimes - code will "clear" over several drive cycles - sometimes code will need to be cleared with Star.
Try this 1st before moving forward to other stuff...
