Battery terminals nut & bolt size?
Old Apr 21, 2017 | 08:36 PM
isamu's Avatar
Hi guys,
I plan on connecting
*THIS* *THIS*
Power Inverter in the trunk of my E-430, but don't know which cables to buy because I need to know the correct nut and bolt sizes(in inches) for the battery terminal. The primary one I'm considering is this one:
Amazon Amazon
...however they only state that the ring terminal size is available in either 5/16" or 3/8". Which of these terminal sizes will properly fit around the battery terminal bolt without being too tight or too loose?
Any help would be greatly appreciated, thanks.
Old Apr 22, 2017 | 03:41 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
0 sized cable for 400W inverter is bad overkill, but nothing wrong with that.
MB is using 2 sizes of bolts on battery clamps, so check what you actually have.
The bigger bolt, having 13 mm head is 8 mm.
The smaller one with 10 mm head is 6 mm.
Hope you can convert mm to inches?
For permanent installation you need to add breaker/disconnect switch. Inverters do have big parasitic discharge.
Don't forget good ventilation.
Old Apr 22, 2017 | 04:47 PM
isamu's Avatar
Thanks. But why do I need to add a breaker/disconnect switch? The inverter I listed already has its own on/off switch.
Old Apr 22, 2017 | 07:22 PM
kajtek1's Avatar
In case you drop a wrench between inverter terminals - its internal breaker will not act.
With internal switch I would double check. Usually they kill the electronic side of inverter, while leaky 12V side will keep on drawing from the battery. Not o problem on daily driver, but if one time you leave the car for few days you might have unpleasant surprise. I am caution about the "low voltage shut off" as those are usually set to save the battery from destruction, not necessary leaving charge for engine start.
The best would be high-amp relay that would activate with ignition on, or a timer if you want to use inverter with engine off.
