Car Vibrating when travelling between 60km/hr to 80km/hr
Old Jul 22, 2017 | 04:51 AM
garykb_ong's Avatar
August 1996 W210
Hi all, I have a August 1996 W210 E200. This car vibrate when it travel between 60km/hr to 80km/hr, it stop vibrating after 85km/hr or below 60km/hr. I have changed 2-times recon "long Shaft , new long shaft coupling, new stabilizer bush, recon steering rack (with alignment), 2 new front tires, new front wheel bearing. But the vibration still not resolved. Please help what others parts that created this vibration. My email: garykb_ong@yahoo.com
Old Jul 22, 2017 | 05:18 AM
Jan AMG's Avatar
The best or nothing
Check differential height shim (0-4mm) and replace dif and tranny mounts.
Old Jul 22, 2017 | 11:13 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Inspect flex discs on driveshaft and the center support bearing.
Old May 23, 2021 | 11:26 PM
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
Good Info
Old Jun 2, 2022 | 09:11 AM
H danielle's Avatar
E240 w210 year 2000 v6 2398 c.c
My car is w210 320 petrol model 2000 ,,same vibration problem from 40 to 60 km/h only in the beginning of moving after moving 12 km it is gone i ve checked all suspension parts tires rims and all r good unless that bushes I don't know if it works or not ,Did u mean this bush ?? Remove it or change its thickness ? If it is 4mm changed to 3 or 2 mm ...waiting ur reply ..thanks
