W210/ Parameter steering option gear to replace regular and DIY control
Old Aug 31, 2017 | 12:06 PM
pocale's Avatar
'02 W210/STW/220cdi
Hi,
A few months recent '02 W210 STW heavy steering in getting annoying enough to consider a reman steering gear (understood the gear usually worns out, not the steering pump).
As far as i understand, the Parameter Steering -option offers more power assist than regular steering at low vehicle speeds. This car has regular steering option. I would prefer a light power steering feel, even at highway speed.
That said, i might want to purchase a Parameter gear, then manually feed the control signal to the steering gear for a max power steering.
If you know, please share
- does the Parameter-option gear has max assist without control signal (unplugged) or min?
- from the gear point of view, how is the assist level controlled: voltage change or square wave... low voltage = low assist level or vice versa?
- is there available the plug electrical pinout schema?
Thanks.
