Battery Charge light
Old Oct 6, 2017 | 01:02 AM
Champaign W210's Avatar
E300
i have a 1997 E300 Diesel. I recently changed my battery and alternator because i had a battery light message; however the Battery charge light message on the dashboard continues to show up in the mornings or after eight hours of not moving the car. My alternator that i got was a reman from an auto parts store and, my battery is brand new. I don't know weather to consider getting a genuine reman alternator and genuine battery from the dealer or not. Has anybody ever experienced a problem like this? Also the car turn on perfect in the morning or after 5 to eight hours of not moving it. Furthermore it does not lose any power while driving.
Last edited by Champaign W210; Oct 6, 2017 at 01:10 AM. Reason: For got to add my question.
Old Oct 6, 2017 | 11:03 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Sounds like poor alternator, but check the car voltage next morning.
If you have climatrionic, you can display it there, what usually shows 0.5V less than at battery clamps.
If not, you use cigarette lighter socket, or just attach multi-meter to battery clamps.
You battery should show healthy upper 12'v when you enter the car.
That will drop when you turn ignition and GP, but after engine start it should immediately go to 13 +V
Good charging voltage is 13.5 -13.8V
